I would like to replace the fuel injectors for a 95 non-turbo manual 850.
They are the original ones (orange).
FCP has the yellow ones from Bosch (pn 945455) but was told by service that they are for automatics.
Really? Automatics use a different injectors than for manuals?
95 850 fuel injector compatibility
- Been thanked: 4068 times
Here’s the fitment chart from the Volvo parts web store. No mention of transmission part split
- misha
- Has thanked: 155 times
- Been thanked: 432 times
There is no difference between fuel injectors for automatic or manual transmission car with same engine and management.
Fuel injectors are coded with colour & Bosch part number which determine their flow and resistance.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
rguzz
- Year and Model: 1996 850 turbo
- Been thanked: 25 times
Unless you are dead set on replacing them, you might consider having them tested and cleaned, www.mrinjector.us. They do a nice job and will give you before and after specs. I had mine done at around 230k and the before cleaning spray pattern was fine, essentially.
- 1035 Views
Last post by northernlights
- 1420 Views
Last post by southofmotown
- 955 Views
- 1326 Views
Last post by erikv11
- 18 Replies
- 4419 Views
Last post by rgk
