I'm looking at a car for sale that needs a replacement power steering rack.
Two questions:
(1) Is this a reasonable seller and part, or are there better options out there?
https://www.pelicanparts.com/More_Info/ ... 003606-INT
(2) Is this replacement job hard to do if I have tools and jack stands, and have done brake and clutch jobs? Only thing I'm missing is the tie rod separator or ball joint fork in this list if needed https://www.liveabout.com/diy-replacing ... ck-4083852
Thanks!
82 264 GLE Steering rack
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Something that has been posted on other sections of the forum would be to avoid Cardone.akm wrote: 15 Oct 2022, 09:54 I'm looking at a car for sale that needs a replacement power steering rack.
Two questions:
Thanks!
Been a while since I've owned or worked on a Brick, the job should be pretty straightforward. If you can do a clutch, this is within your grasp.
If the rebuilt rack doesn't come with outer tie rod ends, count the turns when you take yours off, that should get you ballpark on toe-in.
- 901 Views
Last post by 93Regina
- 598 Views
Last post by Tgmitchell
- 688 Views
Last post by volvolugnut
- 1229 Views
- 30 Replies
- 27125 Views
