1998 Volvo S70 T5
I'm trying to repair or replace a vacuum line that goes from a nipple on the air box located behind the MAF to the FPR. This line has a rubber elbow, with a short piece of white plastic tube and is suppose to attach to a short rubber hose, that attaches to a steel, or some type of metal, tubing that runs the length of the lower radiator pipe toward the passenger side where it attaches to a rubber hose. The problem is the end of the metal pipe at the driver's side looks like it twisted apart at the squeeze clamp and is damaged. I may have damaged this when I replaced the heater core.
I'm thinking of removing what's left of the steel pipe, cutting the bad end and attaching a longer rubber hose. Cutting this pipe will take some skill since it's diameter is quite small and it might collapse the opening, Or, I might take the pipe to a nearby tube and hose shop and have one made. Also, I'm thinking of not reusing the rubber elbow and plastic tube, but just a longer rubber hose to the nipple on the air box.
Has anyone tackled this repair before? Looking for some better ideas.
Vacuum Tube from Air Box to FPR, Repair or Replace?
- Has thanked: 311 times
- Been thanked: 817 times
Any way to get the connection made s fine, rubber, silicone, metal ...
Here's a great resource (first couple pages, anyway!); consider thin copper line as an alternative to repairing the pipe viewtopic.php?t=54895.
- 1965 Views
Last post by Traki56
- 12 Replies
- 9533 Views
Last post by michael8888
- 881 Views
Last post by misha
- 780 Views
Last post by superfeed
- 3219 Views
