'02 V70 (Power Steering Return Line Ftg End)
Mr. Detail
Year and Model: 2002 V70 N/A
Has thanked: 157 times
Been thanked: 6 times
Post by Mr. Detail »
Hi Guys. Just wondered if anyone can tell me how the opposite end of the rubber hose end gets attached or tightened down?
I can't see real well down towards the firewall. (See attachment for clarity)
PS Return Line End.pptx
(116.37 KiB) Downloaded 83 times
Has thanked: 1609 times
Been thanked: 4065 times
It’s a thread fitting with an ring angle seal. It is not a flare fitting, common mistake.
It can be very hard to break the steel thread out of the cast power steering rack thread
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
Verify your fitment, don't go by parts diagrams necessarily. Some are push-in connections with O-rings instead. Both of my 2004 models had 4 different rack configurations possible.
04s60 2.4
04xc70 2.5t
Mr. Detail
If it is very hard to break the thread loose down there below, then perhaps I should just cut off say an 1" of the rubber hose end and re-attach it to the new reservoir. It is the rubber hose end near the reservoir that seems to be causing the leak. Not sure if there is enough slackmin that hose end part.
br0dy519
Post by br0dy519 »
The reservoir itself leaking is common too. You might want to upgrade to the 2005+ version which has an improved design. There is enough slack, but if the hose is Ok it might just be the hose clamp needs replacing or tightening.
04s60 2.4
04xc70 2.5t
