P2 Can someone tell me what this part is? 31400692
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
Vacuum pump switch. Easily the most popular part identification request on MVS.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- Has thanked: 2199 times
,,, and fix that, stat.
If the vacuum pump runs all the time it will burn up and it co$$t$$$
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
Can you tell us all which system this pump is in and it’s function? Could this be the quiet motor you hear sometimes after shutoff?
- br0dy519
The pump provides vacuum to the brake booster. It only runs to build vacuum when you turn the car on, and subsequently after that when you depress the brake pedal only if the switch hasn’t detected enough vacuum pressure. You can test the function of the pump by putting your key into position 2, disconnect the electrical connecter on the switch. Jump out the two terminals on the wire pigtail. The pump should engage.
Motor sound after shutdown could be blower motor, ECM/TCM cooling fan, or rad fan.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- BlackBart
Good explanation, thank you.
So the engine doesn’t produce enuf vacuum for the booster? Or is this a factor of a turbo engine and boost vs vacuum?
It is on both NA and turbo P2 cars And has more to do with CVVT. there are times when CVVT position destroys engine vacuum and the pump ensures that the brake booster has vacuum at all times
I thought it was Intake VVT that does this but I think jimmy corrected me on that
- br0dy519
My non-turbo 2.4 has a vacuum pump too.
Edit: I suppose thats redundant information, i always read “NA” as North America
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- 1528 Views
Last post by ldenorio
- 1523 Views
Last post by TheOtherside
- 2792 Views
Last post by Geno9707
- 1405 Views
Last post by JoeRL
- 2161 Views
Last post by Richard_TD
