Provocative title, no videos
Quick note on those doing a clutch job. I managed to solo, in about 5 minutes, install the transmission by...
Holding the. Engine flat on a crane on a cheap folding table surface. Not too much weight on table, got crankcase sump flat
Visually aligned clutch splines on pressure plate install
I slid the m56 into position on the table, then lifted the back of it to make it square to the engine. I braced it with 2x4 so it held square as I slid it
Visually saw the transmission shaft lineup with the clutch disc
Eased the transmission on until I could start two of the m10 holding bolts up top.
Applied pressure to m56 while turning the crank pulley 5-10 degrees to help splines mesh
Once the gap is down to 1 cm you know the splines are right and you can carefully draw it in with the bolts and light hand pressure on the ratchet. Stop and fix if it gets tight, don’t crack your transmission
The M56 weighs about 35kg/ 70 pounds dry. Easily handled.
P80 m56 mating with engine , one procedure
- 7226 Views
Last post by Volvoblackdog
- 4762 Views
Last post by vtl
- 16 Replies
- 11749 Views
Last post by januwan
- 12 Replies
- 7445 Views
- 3343 Views
Last post by Sveedy
