Need Help Please 2006 V50
Hello All I would really appreciate any and all help with this. Ive had this car a month . Had to replace a cracked upper radiator hose. after getting that done . Car was running when I noticed I had not plugged in the MAF sensor When I plugged it in the motor immediately stopped. I tried to start it but just cranks and cranks. will not start with sensor connected or not , ran the codes P0100 and P0110 . installed new sensors for both codes. check all the fuses under hood and dash. I have looked for days all over internet for some answers but found nothing .If you have and ideas PLEASE let me know. Thank you Roady
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
Perhaps the same issue?roady61 wrote: 18 Nov 2022, 19:56 Hello All I would really appreciate any and all help with this. Ive had this car a month . Had to replace a cracked upper radiator hose. after getting that done . Car was running when I noticed I had not plugged in the MAF sensor When I plugged it in the motor immediately stopped. I tried to start it but just cranks and cranks. will not start with sensor connected or not , ran the codes P0100 and P0110 . installed new sensors for both codes. check all the fuses under hood and dash. I have looked for days all over internet for some answers but found nothing .If you have and ideas PLEASE let me know. Thank you Roady
2007 XC90 3.2 Trouble code P0110 and P0100
viewtopic.php?t=64064
- 1604 Views
Last post by shiloh51933
- 4126 Views
Last post by dikidera
- 1412 Views
- 1625 Views
Last post by Irhuma79
- 730 Views
Last post by plumplum
