Power Steering Pump pulley
Dave0304XC
Year and Model: 2003 XC70
Been thanked: 3 times
Post by Dave0304XC »
Hello, 04 V70, 2.4, my power steering pump is groaning when I turn the wheel, figured I needed a new pump. Easy enough switch out. Ordered a TRW pump from a major online supplier out of Connecticut, got the pump with pulley, pulley is almost 1/2" larger in diameter. Tried mounting it up, but couldn't get the belt on (cause pulley is so big I figured). The online retailer said that's just how they come and that I (???) should switch out the pulley. Yeah that's their solution, I should switch out the pulley. I don't even have a puller. Has anyone purchased a PS pump with the correct (I measured 5 1/8") diameter? Where should I look? Thanks!! Dave
Has thanked: 1609 times
Been thanked: 4065 times
Dave..try seating the belt into the PS pulley and putting the last loop onto the idler instead
MDK
Year and Model: 2004 S60R
Been thanked: 42 times
Post by MDK »
Hey Dave.. I had the same issue with my 2004 v70 R.. the power steering pump pulley was smaller on the R than another one I pulled from a 2.5 turbo. I just got the longer belt. Secondly, the whining can be coming from the reservoir.. if it's bubbling while idling.. replace reservoir MDK
Dave0304XC
MDK- well it only whines when I'm actually turning the wheel. I heard that's the sign of a bad pump. I will look inside the resivour while it's running see if im getting bubbles. D
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
Dave0304XC wrote: 26 Nov 2022, 14:32 MDK- well it only whines when I'm actually turning the wheel. I heard that's the sign of a bad pump.
or low fluid level.
firstv70volvo
Year and Model: V70 T5 2001
Has thanked: 52 times
Been thanked: 123 times
Post by firstv70volvo »
Dave0304XC wrote: 26 Nov 2022, 14:32 MDK- well it only whines when I'm actually turning the wheel. I heard that's the sign of a bad pump. I will look inside the resivour while it's running see if im getting bubbles. D
Here's what causes the fluid to aerate and cause pump noise, the return tube inside the PS reservoir cracks.
If your PS reservoir is bad and based on my experience I'd recommend buying a Volvo genuine part or Vaico brand part (FCP EURO and RockAuto have them), the other aftermarket reservoirs I've purchased had a short lifespan.
Dave0304XC
Wow! That's amazing. Would NEVER have thought a failure like that could happen. But, my V will be 19 years old in 2023, and plastics do break down. D
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
Thats why any model below 2005 I recommend upgrading to the 2005+ reservoir style. Did it on both my p2’s. Easy swap out
04s60 2.4
04xc70 2.5t
