‘04 XC 70 - Aftermarket CAT fit issues
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
So, Ruby Red developed a CAT leak at one of the support stay weld points. The Volvo Cat is NLS, not that I would have ordered one. I got a DEC from Partsgeek, which is Cat and flex pipes and is alleged to be a direct fit replacement. It was not a good fit. Local mechanic spent time heating the flex pipe and bending as well as enlarging the bolt holes on the flange to make it fit. I am betting the Magnaflow ($250 more expensive even after a coupon code) is the better option.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
E Showell wrote: 24 Nov 2022, 06:20 So, Ruby Red developed a CAT leak at one of the support stay weld points. The Volvo Cat is NLS, not that I would have ordered one. I got a DEC from Partsgeek, which is Cat and flex pipes and is alleged to be a direct fit replacement. It was not a good fit. Local mechanic spent time heating the flex pipe and bending as well as enlarging the bolt holes on the flange to make it fit. I am betting the Magnaflow ($250 more expensive even after a coupon code) is the better option.
I suspect he didn't build a wooden jig before cutting the old one.
mine is leaking at the support stays welds too, i'll be welding them up next spring.
Has thanked: 1610 times
Been thanked: 4065 times
You can also grind off the ill- fitting flanges , and put bear river converter flanges on and weld or band clamp them with putty
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
Same car. Same leak here. Please post the model/brand of the cat you selected so I don’t make the same mistake. Looking at some of the pictures, I think theres a cataloguing issue as some of the aftermarket cats don’t look anything close to the original with supports, and claim to basically fit any model Volvo 01-07.
I was eyeing this one, it looks to be correct, and a great price. https://www.ebay.ca/itm/114076540656
04s60 2.4
04xc70 2.5t
E Showell
Post by E Showell »
I used the DEC brand cat and flex pipe combo listed on Partsgeek for about $328. You can check the website for the model #.
'95 855 auto (sold)
