I’m having trouble determining the part needed or issue I’m having with a coolant leak. It appears to be coming from a fitting on the drivers side of the engine. Here is a video. (I mention that the house looks like it goes into the block or water pump etc. I realize now that’s not the case. https://youtu.be/Sv22717VdZo.
I also noticed that that fitting looks like it has grooves in it for one of those metal wire clamps (not a worm gear clamp but the simple wire ones that you just push in. ). There is not clamp present. Possibly the issue?
2008 xc70 coolant leak ID (drivers side of engine)
Bluegrassxc70
- Year and Model: 2006 xc70
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 120 times
- Been thanked: 189 times
Looking at the Video I think you need
Take a look at this post for the first cousin with the same 3.2 as yours
https://www.freel2.com/forum/topic38639.html
If you don't mind the part coming in a LAND ROVER box then get this
LR005564 - Coolant Hose
If you have to have a VOLVO part then
30774513 - the same hose but in a blue box
Since you are going to drain the coolant you should think about replacing the Thermostat and another small hose
https://www.freel2.com/forum/topic32245.html
Good luck
Paul
2008 LR2 3.2
2010 S80 3.2
Good luck
Paul
2008 LR2 3.2
2010 S80 3.2
- 2985 Views
Last post by SuperHerman
- 1086 Views
Last post by MadeInJapan
- 979 Views
Last post by odaikorob
- 23 Replies
- 6014 Views
Last post by roscoerich
- 419 Views
Last post by yanga001
