1995 850 “manual” swap help
notavolvoguy
Year and Model: 1995 850 glt
Post by notavolvoguy »
I have a manual 95 850 glt. I’m swapping in the turbo motor from an auto T5R. I moved over motor, ECU, dash wiring, cluster from the donor car minus the auto wiring and TCU. I’m getting a no crank and I think it might be because the ECU is looking for the park/neutral signal which it’s not getting because my wagon is manual and none of the wiring is there. I can’t just jump pins on the auto harness. My thought is to try and jump pins wherever the auto harness goes to from the Center console. Where does that harness go to? Is there another way to get the ECU to think it’s in park/neutral? Does anyone have wiring diagrams for both cars?
Thanks in advance!
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
Google "1995 Volvo 850 wiring diagrams".
You'll find what you need.
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
notavolvoguy wrote: 26 Nov 2022, 10:37 I have a manual 95 850 glt. I’m swapping in the turbo motor from an auto T5R. I moved over motor, ECU, dash wiring, cluster from the donor car minus the auto wiring and TCU. I’m getting a no crank and I think it might be because the ECU is looking for the park/neutral signal which it’s not getting because my wagon is manual and none of the wiring is there. I can’t just jump pins on the auto harness. My thought is to try and jump pins wherever the auto harness goes to from the Center console. Where does that harness go to? Is there another way to get the ECU to think it’s in park/neutral? Does anyone have wiring diagrams for both cars?
Thanks in advance!
Everybody's friend Robert may talk about it in one of his swap vids. See if this helps from V/S:
http://volvospeed.com/vs_forum/topic/11 ... ring-help/
And he could cover it here, even though it's not what you're doing:
You didn't mention the year of the donor car, please tell us it's not a '99+.
notavolvoguy
Donor car was a 96.
I’ll check out Robert’s stuff. Thanks!
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
Look through these results: search.php?keywords=swap+TCU
I know we've covered this, but I didn't look through those results to find where.
Also -> Amazon link
Chuck W
Post by Chuck W »
foggydogg wrote: 26 Nov 2022, 19:21 You didn't mention the year of the donor car, please tell us it's not a '99+.
He said the donor was a T5R, so a '95 as well.
