How did you change your O2 sensor without a lift?
JimBee
Has thanked: 33 times
Been thanked: 43 times
Post by JimBee »
I have the new Bosch O2 sensor and of course need to remove the old one. Last time I tried this swap on another 850, couldn't budge it and had a shop do it. This time I'm determined. I'm planning to put heat on the sensor lug, but I want the best wrench ready when it gets up to temp.
So I bought a 7/8" 6 point deep impact socket, cut the leads off the existing sensor and the socket isn't deep enough to reach the nut. Not to be defeated, I'm trying to hacksaw about half of the sensor barrel off, but there seems to be a core rod or something that isn't scathed by my sawzall with 18 TPI blade. It goes through the outer tubing easily, but something in the core is very hard.
I realize there's a slit socket which I think is a great idea but in practice it can't hold the rotational force to grip the sensor nut tightly.
If I can reduce the sensor length, then with enough heat I'm pretty confident I can get it out.
How did you change yours? Any suggestions welcome!
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2861 times
Been thanked: 1332 times
Post by matthew1 »
Hi Jim,
Slit socket -- but it wasn't rusted on/difficult to turn. My 850 was on front or side jackstands, I forget which.
Did you try a hacksaw on the sensor?
Also -> Amazon link
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
12" pipe wrench. Then you have it for other things around the house.
1999 V70 GLT
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
I think I used one of the shallow 02 sockets that's offset, but being a low mileage rust free car, it was not stuck. Routing the new wire and connecting it took longer.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Has thanked: 2207 times
Been thanked: 1852 times
If you have a split socket, you can always use a hose clamp around the body of it to prevent it opening up and slipping.
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 114 times
Post by Goupil »
Honestly if it's a turbo and it's really stuck, I feel like taking the whole downpipe out might be easier
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
scot850 wrote: 27 Nov 2022, 07:41 If you have a split socket, you can always use a hose clamp around the body of it to prevent it opening up and slipping.
This is what I do.
brunocerous
Year and Model: 1998 V70
Has thanked: 303 times
Post by brunocerous »
If I recall correctly, I had my two P80s on jack stands and couldn't get enough leverage to loosen the O2 sensors. I ended up wrapping a nylon strap (from a set of ratcheting straps) around the ratchet handle and pulling from the side of the car. It was a little tricky to find the right angle for the ratchet and keep the strap taut while I scooted out from under the car, but it worked for both cars. Hope that helps!
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
Has thanked: 1610 times
Been thanked: 4071 times
Heat is your friend with these. Oxy mapp until they are cherry red and they screw out
I don’t think I’ve used a hacksaw in my cars since I got an 18V Bosch angle grinder, that’s what I would use to shorten an OXS for Removal
