Installed with nary a hitch
Left side
Support muffler
Heat m12 bolts with propane, one minute
Zip off bolts, drop muffler bracket left side, 18 mm hex head
Right side
Heat bolts
Zip of 2 m12 18 mm hex head
Drop and discard rear tow eye receiver
Offer up hitch
Start one bolt right
Start one bolt left bringing up muffler bracket
Zip in remaining 4 bolts, 19 mm hex with lock and flat washers
About 30 minutes total
Some bolt physics.
6 M12 10.9 bolts. Shear strength is 50-75 kNewton or about 10-15,000 pounds each
Thread shear probably about half that
Rated hitch capacity 3500 pounds.
2005 v70NAM56 Catherine curt trailer hitch
Curt C12318 was the product code used here
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
Nicely done. I actually used my hitch today. Rented a u haul trailer for $25 and did a dump/scrap metal run. Trailer weight about 1200lb and load was about 750lb. pulled just fine. My OCD is screaming at you to Buy a trailer receiver plug/cover!
04s60 2.4
04xc70 2.5t
04xc70 2.5t
