I got a service abs system dialogue with the red ABS light, abs seems to pulse quickly when I'm stopping normally.
BCM codes from VIDA are 0011, 0012, 0031, 0041.
0012 is left front mechanical error, all the others are faulty signal.
This past Sept I ran the car in D with the front wheels off the ground to trace a humming sound to a bad front bearing , pass side.
the rear wheels were on the ground, AWD is disabled.
I suspect this would set a code because all 4 wheels were not turning.
Cleared the codes for now, I'll drive it in the morning to see if they come back.
Does my reasoning sound feasible.?
I checked the 30 amp BCM fuse and brake fluid, all good.
04 v70 bcm codes
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
Sounds reasonable.
BCM (and other computers in general) may also fall into a logical state not thought after by the programmers. I had it in couple of occasions, while messing with the CAN buses. You may need to disconnect a battery for 5 mins.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
Here we go, this might be the cause, something went missing.vtl wrote: 07 Dec 2022, 19:06 Sounds reasonable.
Who knows how long I drove it like this. Front driver side, this is where I was getting an ABS fault . duh.....
- Been thanked: 4063 times
It’s nice to find root causes so …..visible
- Stu70
- Year and Model: 2006 Sonic VR GT
- Has thanked: 34 times
- Been thanked: 26 times
Any noises with the missing bolt , no “pinging” on deceleration or anything just the abs?
1998 S70 10v BiFuel - Sold
2006 Sonic V70R - “this is going to be expensive “
- jonesg
slight noise on bumps, hard to pin down from just the noise.Stu70 wrote: 27 Dec 2022, 03:23 Any noises with the missing bolt , no “pinging” on deceleration or anything just the abs?
I didn't really hear much until after finding the bolt was gone. Then I noticed every little rattle.
XC70Rider
- Year and Model: 2007 XC70
- Has thanked: 36 times
- Been thanked: 42 times
Those soft bolts don't require much torque but wonder how it popped out. Did it break off from the stud?
When I first did them on my P2 I broke that soft bolt. Had to extract it then rethread it.
- jonesg
I don't think it snapped, I'll find out soon enough.
Harbour freight torque wrench, should be called talk wrench.
You can guesstimate torque better than this thing.
vtl
Volvo used to sell axle bolts with rubber cone on them.
Here you go, an aftermarket one: www.amazon.com/MTC-171021-30714142-Insu ... B01CGOFX68
