1995 OBD port/module wire bullet broken
lcc014
Year and Model: 855, 1995
Has thanked: 2 times
Been thanked: 11 times
Post by lcc014 »
In my 1995 855, the ground wire bullet of the OBD port/module (under the hood) was broken off. I tried to find a replacement part from dealer and online, no luck.
Do anyone know where I can buy a replacement ?
Thanks,
Ching-Ho Cheng
crlande
Year and Model: 240DL;850;S70
Has thanked: 1 time
Been thanked: 36 times
Post by crlande »
That OBD box can be taken out. Brought mine inside and carefully disassembled it and resoldered that wire. Applied a bit of liquid tape and reinstalled.
lcc014
Post by lcc014 »
Thank you for the reply. However, the broken piece was the plastic white color bullet itself. It broke right at the point where the black ground wire met the white plastic. There was no soldering that could be done to reconnect the wire to the plastic bullet. :(
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Source the needed part from a salvage yard?
lcc014
Post by lcc014 »
volvolugnut wrote: 13 Dec 2022, 09:13 Source the needed part from a salvage yard?
I tried ebay but no luck. I have not tried the local Salvage yards yet.
Has thanked: 2196 times
Been thanked: 1850 times
Sorry we have no junker 850's in the breakers yards up here just now. Sorry!
Robert might be worth a shot on his junkyard tours.
crlande
Has thanked: 1 time
Post by crlande »
Bullet type electrical connector and attach that. Even easier than my process since mine was right at the box. Crimp style or solder. Amazon, Habor Freight, etc. Cheap ass way? strip wire and double up the bare wire on itself to make enough contact between wire and female port.
