Greetings all,
I hope this finds you all well, healthy, and in good spirits!
I have a 1998 V70 T5 that is almost road ready. I noticed a few months ago that power steering fluid was leaking out of the inner tie rod bellow on the driver's side. Any thoughts on what I might do to stop the leakage short of investing in a newer rack? The car has 148,XXX miles on it.
Appreciate your thoughts!
Power steering fluid leaking out bellow
5rivers
- Year and Model: V70 1998 T5
- Been thanked: 15 times
5rivers
1998 V70 M56, silver/grey, has tranny issues, #?# owner, 330,xxx miles, a handy parts car
1998 V70 AT, nautical blue, 2nd owner, 260,000 miles, Sold
1998 V70 AT, T5, forest green, 3rd owner, 172,300 miles, Mimas 16" rims
- Been thanked: 4064 times
Driver side is apparently much harder to do than the passenger side. There are seals that can be replaced. There is an active thread on sources for racks. United and Detroit axle are reasonable cost
- Has thanked: 316 times
- Been thanked: 531 times
Unfortunately you're looking at a new rack. No real way around it. I've had decent luck with Lucas power steering stop leak though, if you're looking to just slow it down to hold you over until you are able to get it taken care of.
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
I noticed the rack on my '97 855 GLT started leaking about 10 years ago. The leak was about 25-50mL per week. I switched from regular ATF to "high mileage" ATF, currently using the inexpensive "SuperTech" brand from Walmart. That slowed the leakage down to less than 25 mL per month which is manageable. Still going OK on the original rack.
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Seal kits are available, but the rack has to be on the bench, and everything has to be squeaky clean going back together. Not a job for the UnBrave.
She probably sets the highest standard for Brave of most anyone I knowNot a job for the UnBrave.
Kally, I have a nasty rack that might get core credit, or might not. Detroit gives you a free shipping label to return the core so that’s free at least. I think they tie warranty to the core
- 5368 Views
Last post by mecheng
- 1197 Views
- 13 Replies
- 7126 Views
Last post by Big Will
- 30 Replies
- 26973 Views
- 6068 Views
Last post by EngineeringBloke
