When I went to replace the lower radiator hose in Blue Steel, the hose I had didn’t have the curved side to reach the engine.
The existing one has that curved section, so I ended up leaving it on.
Is this a known variation, or should I have just bent it to fit?
1998 V70 Base - Different Lower Radiator Hoses
brunocerous
- Year and Model: 1998 V70
- Has thanked: 303 times
- Been thanked: 43 times
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
- Been thanked: 4067 times
There is a chassis break change on the lower radiator hose in 98-99. The earlier hose is longer with the curved end.
Earlier hose “fits” both if you cram the extra on, but to get the factory fit you need the right part
FCP has the wrong fitment in their catalog but some wanker points this out in reviews
https://www.fcpeuro.com/products/volvo- ... ts#fitment
I suspect if you ordered the earlier hose someone’s reboxed it incorrectly.
See here , too.
viewtopic.php?p=550886&hilit=Lower+radi ... nt#p550886
Executive summary
If you have the straight water pipe, heads out to rear of engine, left side of car, you need part number 6842428 or equivalent
If your water pipe connection angles forward to front of car, you need part 9470409 or equivalent
See here , too.
Executive summary
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
You mean this wanker?abscate wrote: 18 Dec 2022, 00:30 There is a chassis break change on the lower radiator hose in 98-99. The earlier hose is longer with the curved end.
See here , too.
Executive summary
- 18 Replies
- 6389 Views
Last post by Mark1967
- 145 Views
Last post by volvolugnut
- 2135 Views
Last post by SonicAdventure
- 2121 Views
Last post by MoVolvos
- 731 Views
Last post by precopster
