Would this be easy to change or very hard to change?
Thanks.
Can I Change My Own Voltage Regulator? 1998 v70
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
It’s possible and hard with the alternator on the car.
It’s easy with alternator on bench
It’s imperative you disconnect the battery either way, for safety
- MrAl
Oh ok, i understand. Too bad, i wanted to see if the charging voltage changed with a new regulator.abscate wrote: 18 Dec 2022, 14:37 It’s possible and hard with the alternator on the car.
The alternator does not look too easy to remove, so maybe some day
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
It can be done on the car, but it's much easier if a few things on the front of the engine are removed for access.
Having a "tucked" cooling fan also grants a bit more room.
- foggydogg
- Been thanked: 405 times
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
I bought a regulator for my 850, but have yet to actually try replacing it. It looks very fiddly due to it's position and things being in the way.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Has thanked: 987 times
- Been thanked: 1075 times
Alternator service is good to consider along with 5 cylinder PVC service.
- MrAl
That looks interesting.
Now you are supposed to disconnect the battery, but when you do that you loose the OBDII information memory.
Can you power the computer through the OBDII connector as usual then, or does that also still power the alternator?
If it does power the alternator, is there a fuse you could pull to prevent that?
- MrAl
Yes it looks kind of tight in there. My old Hyundai was much simpler.454cid wrote: 19 Dec 2022, 10:40 I bought a regulator for my 850, but have yet to actually try replacing it. It looks very fiddly due to it's position and things being in the way.
- 5560 Views
Last post by hans747
- 1752 Views
Last post by tyguyc
- 543 Views
Last post by FireFox31
- 942 Views
Last post by martin calva
- 66 Replies
- 6555 Views
Last post by MrAl
