850R complete engine rebuild + some questions
gofra
Year and Model: 850R 1997
Has thanked: 20 times
Post by gofra »
Hello dear 850 lovers - my first post on this forum!
I'm Frane and I come from Slovenia - a year ago, I found a great looking black 850 R.
Car is in great shape, rust-free & freshly repainted, with completely re-upholstered interior, new Koni suspension, new brakes, new turbo (slightly bigger) charger, Ferrita dp, RIP kit + bunch of silicone hoses and many other little things. It had a fair share of owners beforehand but all the works have been well documented. The engine, however, was on it's way out which wasn't that big of a deal as I planned to do a complete engine rebuild in the first place. Namely, this is my teenage dream come true and intend to keep the car for as long as possible.
So, after a year (and a huge amount of problems trying to find a reliable, capable and trustworthy mechanic!) Volvo finally went to a specialist for an engine rebuild. After engine tear-down, he'll check and measure everything to evaluate what exactly needs addressing. I decided for a rebuild with original parts with the exception of aftermarket forged rods. Since it already has a RIP kit, larger turbo and a 3 inch down-pipe, I'm aiming for healthy 350-ish hp with an emphasis on reliability and driveability. I want the add the least amount of stress to the engine possible, so I'd like to optimise the whole system prior to fiddling with boost. Here are the upgrades I have been thinking of:
- NA intake intake manifold with a larger throttle body opening
- 2.5T exhaust manifold (S60R, XC90 2.5T ...) for better flow
- Maybe NA cams?
- Sport/performance oriented filter panel (open for suggestions) inside the stock airbox
On to the questions regarding the possible bottlenecks:
1. Air Intake
Car currently uses BMC Carbon intake, however, MOT is a bitch where I live so that thing is going out. I already got ahold of a stock intake box and intend to use performance filter panels (such as K&N, BMC or similar) in order to allow the engine to breathe better. Any ideas what figures are possible with a setup like this at best?
2. Injectors
Same question here - what are the R fuel injectors limits power-wise?
3. Fuel / oil pump
Again, same as above - how much can fuel and oil pump handle with it becoming an issue?
4. M56 gearbox.
Car uses an M56 instead of the stock M59 gearbox. How much can these handle before it becomes an issue?
5. Any other possible limiting factors? Clutch?
6. What would be the most logical decision in regards to the ECU to use for a setup like this?
I'd like a smooth power delivery with an emphasis on driveability and not just peak power & torque numbers.
I realise tuning the car up to 350 HP is far from huge but I'm fairly new to the game (aside from reading a bunch and watching plethora of YT videos on the subject) so I wanna play it safe even if that means I'll have to lower my ambitions.
Many many thanks for helping me!
Best
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
White injectors
DW200 fuel pump w/ wiring kit
Wideband AFR setup
Contact Aaron @ Vast Tuning for your ECU
And Welcome !
1999 V70 GLT
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
www.volvospeed.com is your friend on this journey.
There is a lot of tuned Volvos and they will show you the right path.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
misha
Post by misha »
There is a good mechanic in Croatia who knows these cars pretty good.
If i remember correctly his name is Nenad from Jaska,Croatia.
You might try to contact him on www.vkh.hr
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
gofra
Post by gofra »
Will try and reach out to him @misha, thank you!
And thanks to you too, @sveedy!
After some additional reading, I fear that the tranny itself might be an issue over 300 HP.
Has thanked: 2207 times
Been thanked: 1852 times
Clutch might be an issue, but don't think the transmission will be. Auto trans are good for 320bhp, manuals will do more.
20+ years ago in Scotland there was a 850 with a TWR built engine running close to 500 bhp.
gofra
Post by gofra »
You're right. And even clutch can handle it according to this fantastic write-up I found here:
http://volvospeed.com/vs_forum/topic/86 ... t-comment/
Clemens
Has thanked: 500 times
Been thanked: 228 times
Post by Clemens »
The M56 is nicely complemented with a Quaife LSD. 350hp should not be a problem for a M56 with a R clutch. The one thing that is tricky though is the immobilizer for the 96 upward EU models (unless yours is an US import). The german speaking crowd usually reaches out to daniel2345 at volvopower.de for ECU reflashing.
1996 855 R,
2010 V70 D5,
gofra
Post by gofra »
Hey @Clemens, thank you!
I'm thinking of going the standalone ECU way anyways, so that shouldn't be an issue? Speaking of which - what ECU would you suggest?
Clemens
Post by Clemens »
I never dug into standalone ECUs for my projects. I know people have been happy with Haltech and Megasquirt. But Volvospeed or Swedespeed are the better resources for these kinda projects than MVS.
1996 855 R,
2010 V70 D5,
