2005 S60 BiFuel MM ETM priblem
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
I have a 2005 S60 with Magnetti Marelli ETM. How can I be sure I have one of the affected models? I have a brand new Bosch MAF(several months old), so I know it's perfectly fine and working.
But I do have a few issues which I am unsure if I should interpret as a failing ETM or just a few vacuum leaks. Basically when driving the car, and I am at a high speed and press the brakes when reaching a stop, the RPMs fall well below 700(750 is my idle) and in fact I dare say they drop to 500RPM and then after a second or two when I am done braking and have stopped, it goes back to 750.
I have also noticed some RPM hunting, but not a huge amount, but the engine noise gives it away more than the needle does.
And finally, sometimes, I am not sure if I am catching the gearbox in the middle of changing gears, but there is def slight hesitation when pressing the accelerator, like a kick to the gearbox.
sak54757
Year and Model: 2001 v70xc
Has thanked: 3 times
Been thanked: 2 times
Post by sak54757 »
Hi, Over the years I've needed to clean or replace the MAF sensor multiple times, so, even though yours is only a few months old i'd start out by cleaning it. BTW I have have good luck with the Xmodex replacement etm, four years and 50,000 miles...
dikidera
Post by dikidera »
The xemodex thingy costs pretty much as volvo would offer it, especially since they are US based and there is also a hefty 20% VAT on their price. If this was around $200 I might have considered it.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2854 times
Been thanked: 1332 times
Post by matthew1 »
XeMODeX is Canadian, although I'd guess their US sales are greater than their Canadian sales.
Also -> Amazon link
dikidera
Post by dikidera »
matthew1 wrote: 30 Dec 2022, 11:40 XeMODeX is Canadian, although I'd guess their US sales are greater than their Canadian sales.
Doesn't change anything though, still on the America(s)n continent. Anyway, I am curious if my description of the symptoms sound similar to a failing ETM?
Has thanked: 1609 times
Been thanked: 4064 times
Your 2005 would have a Bosch Electronic Throttle Actuator, not the ETM covered in this forum. It doesn’t fail the same way and is much more reliable
dikidera
Post by dikidera »
abscate wrote: 02 Jan 2023, 23:40 Your 2005 would have a Bosch Electronic Throttle Actuator, not the ETM covered in this forum. It doesn’t fail the same way and is much more reliable
Not bosch though, it's definitely marked Magnetti Marelli.
Yagger reminds me Bifuel cars have the MM ETM through the P2 line, was your car ever BiFuel?
dikidera
Post by dikidera »
It in fact is...so I am guessing...it's on borrowed time isn't it?
They run well for about 250,000 km then need service
