Code P0299
Hi I have this code P0299 keeps popping up doesn’t seem to effect car I’ve reset it a couple of time,but there’s also a slight misfire every now and again did it about 5 times on a 100 mile run any ideas on code or misfire.it’s a 2016 D4 diesel 2.4 engine,thanks.
- RickHaleParker
- Been thanked: 977 times
P0200 Possible sources:Pockets1 wrote: 06 Jan 2023, 03:04 Hi I have this code P0299 keeps popping up doesn’t seem to effect car
1. Air leakage in the intake system.
2. Turbo control valve, bypass is damaged.
3. Damaged turbo charger (TC).
4. Turbo control valve wastegate jams.
5. Damaged boost pressure control (BPC) valve pressure servo.
Active
Past
Past
- 1532 Views
Last post by mountaincarjunkie
- 3192 Views
Last post by Orchid70
- 11451 Views
Last post by BBenedek
- 93 Replies
- 28595 Views
Last post by foggydogg
- 25 Replies
- 5813 Views
Last post by Gerd
