Overheating 1997 850 wagon
- Has thanked: 17 times
- Been thanked: 35 times
Most likely bad thermostat...cheap and easy to replace. Turbo or non-turbo? A bit more information would be helpful..for instance what was going on to over-heat the car...what repairs were done recently, etc.
Its now about 8:30 and the car has sat since about 2:00. Iwent to go start it and just turned the key to the on position when the gauge went to the top and the fan came on. The engine is ice cold. When I turned the key back off the fan continued to run for a few minutes. It's never done that before. Even during the summer southern heat, if the fan was running with the car on, it stopped when the car was turned off.
- akitawagon
- Year and Model: 1997 855R
As MIJ mentioned earlier, you most likely need to replace the thermostat, as that is "usually" the cause of the dash temperature display to be reading incorrectly.
While you're doing the thermostat, it would probably be good replace the coolant temperature sensor at the same time while the coolant is drained out.
You need to give us more details on what model car you have as there may be other factors involved.
1998 V70 T5 223K
1997 855R 215K
1997 855R 124K KIA... distracted driver on phone
1997 855 T5 141K KIA... water pump
1996 850 GLT 160K
1995 855 GTA 325K KIA... distracted driver on phone
1993 850 GLTS 201K KIA... t-boned
1997 855R 215K
1996 850 GLT 160K
greasefingerss
- Year and Model: 850 wagon 1994
That would have to be the coolant temperature sensor. If you have an ohm meter unplug the sensor and measure the resistance across the CTS. It should be several thousand ohms at ambient temperature. An engine at operating temperature should read low in resistance (something like a couple hundred ohms) Yours appears to be grounding out.
Current Vehicles
1994 Volvo wagon(855) na 161,000 miles with AT
2003 Toyota Camry
1994 Jeep GC 202,000 miles
2003 Toy 4Runner
2003 Toyota Camry
2003 Toy 4Runner
The temp sensor is at the end (bottomish) of the thermostat housing to the left side of the engine (when facing the car with hood up). The thermostat housing has a hose running to it from the over-flow tank. Hope this helps. Drain or pump out all of the coolant in the tank, then clamp the large hose from the radiator to the thermostat housing and you'll have very little coolant to contend with. Putting an old towel down in that area will help. Other than this, you'll need at least a 5 inch long T40 torx socket (trust me) to clear the fuel lines to undo the thermostat housing screws. You can buy both the thermostat and the sensor from www.fcpgroton.com There are two thermostats. General rule is if you have a turbo car, or live in a hot temp. area, get the lower temperature one. If you drive a non-turbo car or live up north, where temps are generally cold (Canada for instance) then buy the higher temp. thermostat. Good luck and let us know how things are going. Took all but 15 minutes to change my thermostat out when I did mine. I didn't have to do the sensor.
greasefingerss
When I got my Volvo I decided to buy a 7-piece Torx-bit socket set for $ 29 at AutoZone. (T15, T20, T25, T30, T40, T45, &T50) That way I can use them with my ratchet and any combination of extensions. I do not care much for Torx allen-keys, if that
Current Vehicles
2003 Toyota Camry
2003 Toy 4Runner
2003 Toyota Camry
2003 Toy 4Runner
- 1336 Views
Last post by cynlim
- 1849 Views
Last post by ZionXIX
- 1895 Views
Last post by dmg4
- 505 Views
Last post by jeremykentucky
- 2444 Views
Last post by nancynywoman
