Squeaking from Rear Suspension 2008 XC70
IdahoBob
- Year and Model: XC70 02, 04 & 08
- Has thanked: 1 time
- Been thanked: 4 times
150,000 miles, I live in Montana, so car rarely gets hot, but sees really cold (for US, apologies to my Canadian neighbors) From the left (US driver’s side) rear axle/suspension area I have a squeaking noise I cannot locate. Sounds like a rubber bushing squeak. Squeaks for any bump or piece of gravel on road. When accelerating up hill there’s no squeak. When road surface is wet it does it squeak. If I spray the undercarriage at car wash it does not squeak. I changed out the sway bar bushings and sway bar end links ( rubber looked a little worn on both), that did not fix it. Anyone have experience with this one, or good ideas?
Idaho Bob
67, 71, 85, 98 wagons (sold)
78 coupe (gave to mechanic, thanks!)
02, 04 (X2) & 08 XC70's
before that: 67 Sunbeam, several pre-68 VW's, '41 Buick, '42 Ford Jeep, and some boring stuff
CheapAssGus
- Year and Model: 2010 XC70
Is '08 the first year for P3 XC70? I have a similar sounding squeak on mine. I have read when the trailing arm bushings wear, it moves enough that something rubs on a bracket that holds a brake line (I think). Mine will mercifully go away when it's wet but doesn't stay gone long anymore.
truenorth
- Year and Model: 2011XC70
- Been thanked: 8 times
I am tackling similar issue on my 2011 XC70 with 220K+ KM and, in my case, I have concluded it is most likely the rear trailing arm bushing which I plan to replace in Spring. Here is how I came that conclusion: I have relatively new rear springs, shocks, end links. Noise goes away when weather is cold. On warm days, the noise happens when I am turning the car. The give away is both rear tires have noticeable inside tire wear and the alignment shop could not properly align rear wheel toe.
I am now trying to find best way to replace trailing arm bushings without having to spend $500 on tooling...
CheapAssGus
FCP Euro has a Youtube video where they replaced the bushings with Powerflex multi-part bushings. Not for the faint of heart.
truenorth
Actually, it was that video that got me to zero in on trailing link bushing. What I liked about that video: how to remove the bushing with a cutter. What I am doing different from that video: 1] not removing trailing link arm from the car, 2] not installing powerflex bushing because of cost and stiffer ride
CheapAssGus
Were you successful? How did it go?
- 1937 Views
Last post by Miltown
- 17 Replies
- 4338 Views
Last post by Jackazz
- 1122 Views
Last post by shoelacetrain
- 844 Views
Last post by jwcarty
- 1106 Views
Last post by draser
