Hello MVS forum. I am trying to help a fellow Volvo owner. he broke off the fuel filler door on a 1994 940 in 189-21 white. (bracket is off back of door)
the P/N on the door is 3526601. When I type this into searches I get a control arm?
The reason I posted in this part of the forum is b/c it looks like that door can fit 84-92 740, 82-90 760, 91-95 940, 91-92 940SE, 92-97 960, 97-98 S90 and 97-98 V90 vehicles.
Can I use a fuel filler door from an 850?
Anyone have any leads for a white fuel door that would fit?
Thanks in advance.
Fuel Filler door - 3526601
- Has thanked: 2199 times
As you know the part number is listed as NLA on Volvo parts sites. As Volvo have retired the part number it may be why you see it listed for something else.
I found the part on a couple of Volvo sites still listed under that part number but both show it as 'Contact your dealer', that may mean it is available from Volvo Classic or they have just not updated their websites.
The 2 websites I looked at only list it as for the 940/960 ranges only. The shape looks more square than that of an 850 or any other P80 car.
Best chance is to contact Volvo specialist breakers like Erie Vo-Vo and see if they can help you. I rarely see any of the old box shaped Volvos any more in the junkyards around here.
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
No sure what is broken or missing on the bracket but from my experience with the 2000 S70 fuel door and other plastics you can use a combination of hot glue, baking soda, super glue and other adhesives to potentially obtain solid repairs.
On our 03 Honda Odyssey the coolant overflow plastic tank was rubbed through by the accessory belt when it was removed for another repair. Was sitting on the belt when the car started. It is not an expansion tank so no pressure. With a little sanding and 97% alcohol cleaning and a larger hot glue gun I layered it on and around the large hole. Going on maybe 4 to 5 years now?
viewtopic.php?p=580940&hilit=c30+pcv#p580940
viewtopic.php?p=611306&hilit=2000+S70+fuel+door#p611306
https://www.youtube.com/results?search_ ... ic+repairs
bill d cat
- Year and Model: 1998 V70 T5M
- Been thanked: 7 times
Erie Vovo might even have one in the correct color.
Fuel doors are available (used) on eBay. If you watch long enough, one in the correct color should show up - or you could just paint one with a rattle can.
Aftermarket plastic hinges (the plastic hinges often break if you live in a place that doesn't allow self-service gas, like New Jersey) are available on Amazon.
The SVC 70 fuel doors and the 740-940 fuel doors look different to me.
- Screen Shot 2023-01-13 at 7.34.47 AM.png (833.45 KiB) Viewed 556 times
'98 V70 T5 232K mi., 5-speed manual, 3rd evaporator, 3rd windshield, 7th remote shell, heated velour seats, factory HD suspension, IPD stabilizer bar, Volvo strut tower brace and skidplate, XC grill, E-Codes, V-1, JB Weld, Duck Tape, zip-ties, Mobil-1 since new. Goal: MADE IT to the MOON! (was 221,524 miles at perigee November 14, 2016.)
DrJammer
- Year and Model: 2000 V70XC - 195k
- Has thanked: 1 time
Thanks for all this input. I am pretty sure the S70 and 850 doors don't fit, but was looking for confirmation. I have already reached out to erie vo vo and voluparts and the ebay seller from the pic above, no white doors found so far. without waiting, it looks like white rattle can it is. although I am very tempted to try some adhesive
Ex-Volvos
2004 v70 N/A - traded in at 75k
2008 S60 - leased
1998 S70 T5 - might still have her if I knew about this forum when I owned it
2008 S60 - leased
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
What am I missing? Why not just buy a new hinge?
https://www.fcpeuro.com/products/volvo- ... -1380664oe
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
DrJammer
one of the plastic brackets on the inside of the door that the black plastic hinge attaches to has broken off
Ex-Volvos
2008 S60 - leased
2008 S60 - leased
- MoVolvos
.DrJammer wrote: 13 Jan 2023, 11:03 one of the plastic brackets on the inside of the door that the black plastic hinge attaches to has broken off
Please upload a photo. You can also do a wrap which is much easier than paint. Hair dryer for the edges will do, no need for a heat gun.
- MoVolvos
454cid
Ok, I had to do an Ebay search... apparently the whole 940 fuel door is plastic. The P80 doors are steel with plastic hinges.DrJammer wrote: 13 Jan 2023, 11:03 one of the plastic brackets on the inside of the door that the black plastic hinge attaches to has broken off
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- 797 Views
Last post by Schmendrick
- 3646 Views
Last post by DrJammer
- 16 Replies
- 8845 Views
- 2502 Views
Last post by darrylrobert
- 5344 Views
Last post by RickHaleParker
