V70 2001 SRS-00DB
forhike
Year and Model: v70
Been thanked: 2 times
Post by forhike »
I have a v70
I had 16srs errors i could read them but not clear fault codes
Did remove battery and replaced SRS module, found a used replacement from same car and matching hardware and config id.
After replacement i could reset dtc codes, and did have 3 codes left
SRS-00DB
SRS-0034
SRS-00D0
Did lock under the driver seat and connector had came loose i did fix it.
And did connect battery, did first reset cem then srs.
And now i only have this error left
SRS-00DB
But dont know where to lock for faults
Can anyone give me a hint.
Is it left side window airbag. (Going from front to rear window) connector is in trunk roof.
Does it have something with seat airbag, or belt connector.
Or the airbag in dash panel
forhike
Year and Model: v70
Post by forhike »
Did connect with vida and got these errors:
2 pending and 1 static
Pending:
SRS-0026 Passenger airbag, stage 1. Configuration fault. Permanent fault
SRS-002E Passenger airbag, stage 2. Configuration fault. Permanent fault
Possible source
◾ If the SRS
control module
identifies that
an airbag or a
seat belt
tensioner is
installed,
despite the
control module
being
programmed
that neither
should be
installed
Static:
SRS-00DB Passenger airbag. Faulty signal. Permanent fault
Possible source
◾ Incorrect car
configuration in
the central
electronic
module (CEM)
or incorrect
parameter files
in the SRS
system
◾ The car
configuration in
the central
electronic
module (CEM)
or the
parameter file
in the SRS
system does not
correspond to
the car type.
Perhaps i will just try disconect some airbag and read again and see, perhaps i can make my car like to one srs module came from
forhike
Year and Model: v70
Post by forhike »
Did talk to Volvo they could try reprogram srs module for approx 120usd, will try that before i play more :)
