1998 V70 NA - Ignition key replacement
Has thanked: 2199 times
Been thanked: 1852 times
After my debacle last weekend when my friends car decided to lock itself with the one and only fob and key in it, I am looking at a spare key for the car. I spoke to the local dealer and the key was about $85 CDN for a blank!! Then $152 for a cut key.
I was staggered at the cost of the key. I thought that may have been for a shipped key, but no. The parts foreman I know well and he had a 98 T5 and was a mechanic at Volvo so he knows his P80's.
I found another key at a dealer that was only $15 for a blank but that is apparently only a 'valet' key. As it has been probably over 15 years since I had one of those can someone remind my failing brain what the differences are?
If I recall the valet key opens the drivers' door and will start the car, but does not open the trunk/tailgate or glove box??
If I am correct them the owner won't care as they don't lock the glove box and being a wagon it has the internal handle worst case. As the key is just for a back up would a valet key be just fine?
I know there are aftermarket keys out there, on Ebay for example. Can anyone recommend a source for a blank or 2? I can get the keys cut locally relatively cheap if I recall.
Thanks, Neil.
Here, answered my own question! Should have checked Robert DIY videos where he clearly identifies the differences:
Thanks Robert!
Bragg Creek
Year and Model: 1997 850 wagon
Been thanked: 3 times
Post by Bragg Creek »
Hi Neal,
Chris here from Bragg Creek. Saw this post and it reminded me that I never got a replacement key for my 850 wagon. The key cutting place in the NE that you recommended wanted 25 dollars to cut a key but they did not have any blank keys. Found them for a cheap price at:
https://www.volvovancouverparts.ca/p/Vo ... 47947.html
It may work for your needs...Chris
1995 Volvo 850 sedan 10 valve non-turbo
1996 Volvo 850 wagon 10 valve non-turbo
1997 Volvo 850 wagon 20 valve non-turbo
1955 Landrover series one 86 inch
1961 Landrover series two 109 inch
1974 Volkswagen Westfalia Bus 1.8L air cooled
1984 Volkswagen Westfalia Vanagon 1.9L
A whole stable of slow moving, labour intense transportation devices. :D
That key is the valet key and not the 'full' key Chris. I may go that route as I mentioned above as it is only for emergencies as the lady only has one fob and key, so anything that can open a door to recover that would be handy. The blank from Volvo of Vancouver is around $60 if I recall. There are much cheaper options out there for non-OE blanks.
Wow, that is inflation for you! $25 for the key cutting now. Ouch! There is another place in the NE that claims to cut and program keys. I will talk to them at some point and let you know if I have any success there.
P80GLT
Has thanked: 154 times
Been thanked: 176 times
Post by P80GLT »
I think it would be possible to file the valet key to allow it to be used as a master key
1997 850 GLT website
2010 XC90 SE...SOLD
2005 V70 2.5T SE
Maybe be worth a try. Thanks for the idea!
