The Columba wheels on the 850 had been powder coated before I bought the car. The spare is still original and the outside is still in good condition, however the inside has suffered from salt getting in and causing damage to the aluminium so it required tidy up. As it's only the spare wheel I decided rather than go down the route of powder coating I would paint the inside (inside rim was originally painted when new and not powder coated) and the outside is still presentable. Some serious rubbing with 60 grade sandpaper removed the rough and I finished off with some emery cloth. Etch primed and some grey primer then a couple of coats of clear lacquer before applying a coat of wax.
My method for spare wheel refurb...
- Been thanked: 4063 times
The asymmetry of having three LH Columba’s and two RH Columbas would keep me up at night…
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
Wow, a spare wheel that uses an aluminum rim? Mine is steel which is typical in the US and I would have assumed worldwide for all/most manufacturers.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- June
- Has thanked: 523 times
- Been thanked: 261 times
My 91 740 also has a matching aluminum wheel as a spare. Perhaps it was optional equipment? June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
- Has thanked: 2196 times
- Been thanked: 1850 times
The spare wheel well in rear wheel drive Volvos used to have full sized spares with a steel wheel and tire. When Volvo went to the P80 and FWD they went to the smaller donut spare, but you can usually fir a full sized wheel and ire as you can see.
- 1165 Views
Last post by Smirenka
- 2142 Views
Last post by Richard_TD
- 1584 Views
Last post by dosbricks
- 1772 Views
Last post by JimBee
- 1113 Views
Last post by bmdubya1198
