98 V70 exterior handle locks and unlocks but won't open door
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
So I definitely screwed something up when replacing my door handle. I got the peg to go in the slot, so the lock cylinder works. But when I pull in the handle it sounds like it scraping past whatever lever it's supposed to catch to open the door. How am I supposed to put this thing back together?
Knows enough to be dangerous
- Has thanked: 2207 times
It could be the lever that has the round end on it got bent or has not fully engaged in the slot it has to get into. I have been there and it seems it either goes really easy or will fight you all the way. If the arm gets bent it can rub against the rear window guide.
If you have not already watched these from our friend Robert DIY then it may help shed some light:
- 887 Views
Last post by fmwaz
- 1117 Views
Last post by Volvo S80
- 2796 Views
Last post by a50sGreaser
- 1113 Views
Last post by adrian22
- 1469 Views
