Front end looseness feeling (ABS Module?)
famfeld
Year and Model: 04 xc70
Has thanked: 9 times
Been thanked: 6 times
Post by famfeld »
I was driving home from work as usual and traveling around 45 mph on back roads. I suddenly felt a loose and wandering feeling in the steering like a bad ball joint or really worn control arm. It seemed like it was coming from the left front wheel, like it was pulling left. I pulled over and looked over everything and didn't see anything obvious. Then when I got going again, I had the same symptoms. Now upon breaking, I felt the ABS releasing, where it normally wouldn't. I'm wondering if the ABS control module could be acting up and causing this. I had issues with it in a P80 Volvo before. The symptoms went away completely and now it felt totally fine for the rest of the ride home (25 mins or so). Any ideas?
Thanks,
Feld
Krons
Year and Model: 08S60 05XC90 02S60
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
Any codes? If ABS I would assume there is stored codes.
08 C702.5T (sold)
The non-Swedes:
Has thanked: 1609 times
Been thanked: 4063 times
It could be a wheel sensor or tone ring problem triggering the ABS. You can see data for this in VIDA or a good scanner
famfeld
Post by famfeld »
I need to scan it. I'll do it today. This is what happens when your check engine light is always on due to an aftermarket cat.
Thanks for the help.
famfeld
Post by famfeld »
I think salt may have gotten on the ring or the sensor and it was triggering the ABS. Maybe. When this happened, they had just put a whole bunch of salt on where I was driving. I'll scan later hopefully.
