Hello
After water infiltration inside the car, i encounter a few problems and i would need an advice :
- blower fan do not work, but LED is okay on the CCM panel
- rear defrost does not work and no LED, but it sometimes works after driving for a long distance
- air flow distribution servo motors and the air recycling flap do not work when I operate the buttons on the central panel
- air con. seems to engage properly because when i switch it on/off i can hear the engine changing its speed., but of course no air flowing
- fuses all checked and OK
After a few thinking, i suspect that the CCM has electrical gremlins that may cause all those problems, because it is upstream of all those peripherals.
Do you think i could be on the right way, or is my theory unfounded ?
Thank for your advices !
Raphael
CCM gremlins || 2008 - V70 III 2.0
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
Comment l'eau est-elle entrée ?rafa226 wrote: 10 Mar 2023, 04:38 After water infiltration inside the car, i encounter a few problems and i would need an advice :
rafa226
- Year and Model: 2008 V70 III
The water came in through the top of the windshield:
On each side of the windshield, there are gutters, and they were clogged (Sahara dust that we have sometimes in south of France when rains comes from the south).
It snowed, the snow stayed on the car for 2 days, and when it melted, the water seeped in through the top windshield seal...
So the water dripped from the car's ceiling light, and i am pretty sure, ONTO the CCM.
This afternoon, I removed the climate control unit and cleaned it with contact cleaner. Without any effect. But I was able to observe that it had gotten wet.
xHeart
The Cabin Air Temperature Sensor is a key component in CCM.rafa226 wrote: 10 Mar 2023, 09:52
The small fan inside the assembly draw the air in, passes the sensor, for CCM function properly - else expect a malfunction.
See items #18 in this diagram:
... here is a close up
rafa226
Thank you for your answer. I have seen this little guy, and did my best to clean it without damage because it's so tiny !
A few days ago i've red a topic about the possibility to replace it's thermistor, and, as you say, many malfunctions that could appear because of it.
The specs seems to be 10KΩ @25°C and it's pretty cheap
It surely could explain the blower problems, but do you think it could be involved in the rear defrost LED not working ?
xHeart
I had issue with recirc LED; which resolved itself after the CCM service - blower fan and thermistor clean up.rafa226 wrote: 10 Mar 2023, 10:31 It surely could explain the blower problems, but do you think it could be involved in the rear defrost LED not working ?
The vent collects direct and fuzz build up, it blocks thermistor and obstruct the blower fan. You can place one end of a hose over the vent and other to your ear; with ignition on (not engine running) you can hear the good fan run. Be careful - it's fragile.
rafa226
Thank you for this great tip, i will try it !xHeart wrote: 10 Mar 2023, 13:41 You can place one end of a hose over the vent and other to your ear; with ignition on (not engine running) you can hear the good fan run. Be careful - it's fragile.
Also, i noticed there was the same vent in the dome light, do you know if it's the same purpose ?
- 3888 Views
Last post by Blacklab467
- 3880 Views
Last post by Drivin4dollas
- 915 Views
Last post by matthew1
- 1659 Views
Last post by jjlch
- 3624 Views
