2003 volvo v70 map sensor help
ThaBearjew6989
Year and Model: 2003 volvo v70
Post by ThaBearjew6989 »
Hello everyone, i recently had my check engine light come on, got codes emc 100a (ecm internal fault, baro sensor faulty signal) and ecm 140a (map sensor faulty signal)
Where is the map sensor exactly on this car? I uploaded a picture of something I wasnt sure what it was and maybe that is it?
Car is getting increasingly worse gas mileage and surge at cold idle.
Thanks for any help
What is this connector go to?
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
That's the camshaft position sensor in your picture. The MAP sensor is part #10 in this diagram. Follow the hose that connects to the intake manifold, I believe it's mounted ahead of the intake manifold but I'm not 100% sure.
ThaBearjew6989
Awesome thank you for the diagram and the identification of the camshaft sensor
I've been looking for couple days on a diagram but everyone I looked at was in a different spot I couldn't find.
I'm gonna go outside and see if it's there.
ThaBearjew6989
Found it, the vacuum hose was disconnected but sensor has no signal so I got to test the map connector and the map itself using a code reader
Thanks again for the diagram and response.
bmdubya1198
ThaBearjew6989 wrote: 22 Mar 2023, 20:17 Found it, the vacuum hose was disconnected but sensor has no signal so I got to test the map connector and the map itself using a code reader
Glad you got it figured out!
SOURDOUGHJIM
Year and Model: 2004 V70 2.4
Has thanked: 55 times
Been thanked: 28 times
Post by SOURDOUGHJIM »
'04 V70, after changing oil and a dump and fill on the trans, CEL came on. Still runs OK with a slight hunting at idle. Oreillys read the code for me, P2227, MAP sensor. I bumped the hose off the manifold while filling/checking the trans. Thanks to bmdubya for the MAP sensor drawing!
SteveOV70
Has thanked: 3 times
Post by SteveOV70 »
Hey can someone tell me in that diagram what #14 is? I don’t think Iv never noticed that b4 on the left side
Of my engine? Also where does #17 go? It’s just randomly there on the print lol. And laaaaastly does anyone know if there MAP sensor the hose that come directly off the MAP sensor does that have a clamp? Or is it just there holding on by itself?
bmdubya1198
SteveOV70 wrote: 08 Jun 2025, 11:15 Hey can someone tell me in that diagram what #14 is? I don’t think Iv never noticed that b4 on the left side
It's this part https://www.volvopartswebstore.com/prod ... 31288.html
SteveOV70
Post by SteveOV70 »
Hey thanks much appreciated
SteveOV70
Post by SteveOV70 »
Hey does anyone have a wire diagram for the cam position sensor? I Tryed a search and nothing came up?, mines a 04 V70 2.4 FWD
