Howdy folks,
looks like my dearest Helga has gained access to a donor head sooner than I could configure the space & muster the courage to attempt my first valve job.
Anyway, my Google-fu is failing me today so I figured I'd cut to the chase here. My wagon is an '01 2.4L, whereas the donor wagon is an '04 2.5L.
Would this be a straight swap, or are there variables I should be aware of?
As always, thanks for your time!
Swapping head from 2.5L engine to 2.4L
- chris11211
- Year and Model: 2006 s60 2.5T
- Has thanked: 7 times
- Been thanked: 29 times
It's possible that the one of the two vvt solenoids holes in between the timing belt and 1st cylinder could be uncut. Because I know some engines can only have the exhaust holes cut to be used for the solenoid and has the intake uncut. I'm not sure if it's due to the year or engine model, but that's a possibility.
Just unscrew the two T30 bolts next to the timing belt, see how many you got and compare with pics from the donor.
- 261 Views
Last post by sillywabbit1233
- 777 Views
Last post by MadeInJapan
- 647 Views
Last post by harryhendo
- 18 Replies
- 13203 Views
Last post by V7025t
- 1867 Views
Last post by RickHaleParker
