V40 No infotainment screen
Segmant
Year and Model: 2014 V40
Post by Segmant »
Hi, new to the forum and looking for help in diagnosing a fault with my infotainment screen/system.
The screen is blank, I have no radio, no USB but the AC controls still work but I cant see what setting they have.
Ive ran it through VIDA and have only two fault codes, that are almost identical
Code: Select all
CEM-U015600 Lost Communication With Infotainment Control Module (ICM)
Code: Select all
CCM-U015600 Lost Communication With Infotainment control module
What do I need to do to trace the fault?
Thanks
Constantino
Year and Model: V40 D2 2014
Post by Constantino »
Do you done your problem?
I have some problem.
woofnohitter
Year and Model: 2024 XC40
Post by woofnohitter »
It sounds like you're having trouble with your infotainment system. Here are some steps you can take to diagnose and potentially fix the issue:
1. Check fault codes in VIDA for specific issues.
2. Power cycle the system by disconnecting the battery for 15 minutes.
3. Check fuses related to the infotainment system.
4. Update the software if needed.
5. Inspect connections to the infotainment unit.
6. Consult a professional if the problem persists.
If you can provide the exact fault codes from VIDA, it might be easier to pinpoint the issue.
Segmant
Post by Segmant »
Hi
I posted the VIDA codes in the original post, maybe read it?
