Hello MVS! For some reason my driver's side mirror keeps moving when I get over 30 MPH. It is the glass/mirror plate that keeps moving. I can adjust the mirror to the top using the controls and it stops but when I bring it back to the right position it keeps flopping all over the place while driving.
Is there anyway I can adjust something or figure out how to fix this? Anyone else have this problem?
Dustin
2013 C30 driver's side mirror moving
- BlackThunder
- Year and Model: 1997 850
- Has thanked: 6 times
- Been thanked: 3 times
Dustin
2013 Volvo C30 T5
1997 Volvo 850 NA Sold to a New Volvo Enthusiast
2013 Volvo C30 T5
Richard99
- Year and Model: 2000 V70XC
- Has thanked: 26 times
- Been thanked: 23 times
Hello,
Yes, I had this problem. The mirror is about to come off the actual assembly. The glue isn't holding it well anymore. My advice would be to try to carefully pry it off the assembly and then re-glue it.
The reason it only happens at higher speeds is because the wind is moving it around.
-Eric
-Eric
Eric
1998 Volvo V70 - rear-ended and totaled
2000 Volvo V70XC
2007 Volvo V50 T5 AWD M66
2000 Volvo V70XC
- BlackThunder
Thanks! Any suggestions/brands to use for glue? Also, it stopped wiggling for some reason now. Who knows why!
Dustin
Dustin
Dustin
2013 Volvo C30 T5
2013 Volvo C30 T5
Richard99
I just used a 5-minute epoxy that you can get at any hardware store. That will hold it really well.
-Eric
-Eric
Eric
2000 Volvo V70XC
2000 Volvo V70XC
- BlackThunder
Ok, I'll check that out. So the mirror part, the glass, will just pry off? Can I glue this while the side mirror is on the car or do I need to disassemble the side mirror?
Dustin
Dustin
Dustin
2013 Volvo C30 T5
2013 Volvo C30 T5
- BlackThunder
I have the same issue. It stops sometimes though, even at high speed. So I wonder if it is the motor for the mirror? That still moves too.
I haven't tried to pry it off yet
Dustin
Dustin
Dustin
2013 Volvo C30 T5
2013 Volvo C30 T5
- BlackThunder
Yeah, thought about that. I ended up using the 5 minute epoxy stuff. It seems to be holding up so far
Dustin
Dustin
Dustin
2013 Volvo C30 T5
2013 Volvo C30 T5
Mine was doing the same thing, but again, only occasionally the past couple of days. Unfortunately, yesterday, it fell out while driving. Any ideas where to get the replacement glass? I need it by tomorrow as I'm driving 300 miles to an event!
- 1730 Views
Last post by darrylrobert
- 5731 Views
- 1687 Views
Last post by 850_GLT_Owner
- 2657 Views
Last post by chrism
- 655 Views
Last post by MoVolvos
