My 2002 Volvo C70 has occasional rough shifting problems. It also has a check engine light, and my cheap code reader says p0440. When I clear the code the engine idle and rough shifting improves.
I suspect there may be a specific Volvo code I'm not picking up and that it might be a transmission speed sensor. I bought the car a year ago and put some money into suspension parts, and otherwise, it runs like a dream.
It has 125k miles on it. Any thoughts?
2002 Volvo C70 HT Convert Rough Trans Shifting
mjdonnelly1
- Year and Model: 2002 Volvo C70
- Has thanked: 2196 times
- Been thanked: 1850 times
The reason it runs better is because the ECU goes back to a preset set of data which means the engine will run better. Once it gathers the fault data again it will run badly again.
P0440 is an emission systems general code. It means there is a leak somewhere in the Evap system. Usual suspects are near the back of the car near the fuel tank and carbon canister on your year of car. It is often called the 'J' pipe from the carbon filter. Check all pipes carefully as in one of my cars the cracks were not visible as they were on the top of the pipe which was hidden.
- 600 Views
Last post by phils94850
- 536 Views
- 25 Replies
- 6055 Views
Last post by goldmandan
- 13 Replies
- 2281 Views
- 2079 Views
Last post by lummert
