I found the hose fitting on the aft side of the air filter box missing a elbow / line missing and just aft of that in front of the fusebox.
Is there an identification of what this line is and part number. What purpose does this missing line serve?
I could not find it.
Thanks.
106 Miles 2 Chicago
2001 V70 Missing Vacuum Line between Fusebox and Air Filter
106 Miles 2 Chicago
- Year and Model: 2001 V70; 2019 XC90
- Has thanked: 1 time
- 2001 V70 AIR INTAKE MISSING FITTING.png (508.55 KiB) Viewed 832 times
- Been thanked: 4068 times
It’s part of the air filter box heated air system. Vacuum comes up to the air box to one of the two nipples, and the temperature of the air box meters the vacuum ftom the other nipple down to the flap that selects hot or cold air into the air filter box.
Those rubber nipples are available from Volvo or aftermarket
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
might not be needed in texas heat.abscate wrote: 09 Apr 2023, 10:55 It’s part of the air filter box heated air system. Vacuum comes up to the air box to one of the two nipples, and the temperature of the air box meters the vacuum ftom the other nipple down to the flap that selects hot or cold air into the air filter box.
- 97 Replies
- 15426 Views
Last post by bmdubya1198
- 3507 Views
- 914 Views
Last post by EstVolvo
- 535 Views
- 6702 Views
Last post by pranayama
