XC90 2003 stalls while driving without any dtc
DJ00
Year and Model: XC90 2003
Post by DJ00 »
Hello
I have a problem with my XC 90 2,5 B5254T2.
It stalls while driving. It appears each few kilometers, or nothing happens for 300 km. Sometimes it can be started directly. Sometimes only from Parking position of the transmission. Last time it was not possible to start again, two hours later the engine ran very raw (like on three cylinders). After a few hours it works fine again till next stalling. Cem and ECM were changed and cloned but nothing changed. There are no DTCs stored.
Can anyone help me?
Has thanked: 1610 times
Been thanked: 4069 times
Have you had fuel pump work done recently? It is very easy to kink the fuel lines on this car which will give this result
DJ00
Post by DJ00 »
Thank you for your response. Yes, I had fuel pump work done. But it was running approx 5000 km fine after the work. Can it be kinked inside the tank or outside?
