2001 S60 base P0113
yabadabadoo1026
- Year and Model: 2001
- Been thanked: 2 times
somewhere got the impressions this was a simple MAF issue----am I incorrect on this???? i've had it out twice and sprayed it good with MAF cleaner twice and code keeps returning?????????????? Gas mileage as a result has really dropped. Any thoughts or suggestions?---thanks
- Has thanked: 2856 times
- Been thanked: 1332 times
P0113 = Intake air temperature (IAT) inlet Signal too low. Intermittent fault
Is that the only code?
yabadabadoo1026
Matthew, ty for the response. Yes sir, that is the only code. What is the fix for this, some sensor? Now im really further hating buying that $9 small MAF cleaner for 3 or 4 squirts in vain
Do you have any friends or neighbors with the same car, or same MAF (you can look it up and find other cars that use this -- I don't know what they are)? Then you can swap for a half hour and drive around and you'll know if you need a new one.
yabadabadoo1026
Guess I'll buy another and hope not wasting $$. Sure suspected a simple spraying it would resolve the code issue
- 1909 Views
Last post by alschnertz
- 1244 Views
- 936 Views
Last post by EngineeringBloke
- 17 Replies
- 4850 Views
- 2119 Views
Last post by SonicAdventure
