95' 854 GLT - Low Power and stalling
fredt2
Year and Model: 850 GLT 1995
Has thanked: 2 times
Been thanked: 7 times
Post by fredt2 »
Hello everyone,
120k miles on my 95 glt, one week ago the car starting to run weirdly, with symptoms as follows:
Rough idling and very low power, the car used to live up pretty easily, with nice mid low torque, now it feels like I truck, having to push the pedal all the way down for it to rev some.
This morning it stalled 4 times in my 5mi commute to work, 3 of those while reversing out of my garage.
Here's what I've already tested and dismissed as cause:
-Already run the car with MAF unplugged, didn't change anything.
-Fixed the stuck flap on the airbox
-Checked the fuel line for leaks and cramps
-Spare fuel pump relay didn't help it
The engine revs freely when parked, only hesitates when driving.
Have yet to try to start the car with the o2 sensor unplugged, is this a good way to test if it's malfunctioning?
Also, as the car is running rough and stalling parked, I really doubt it's the tranny slipping.
I have a decent amount of time spent in this car, but never had anything like that, any help will be appreciated!
fredt2
Post by fredt2 »
Update: took the o2 sensor out and still the same.
Officially out of clues
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2864 times
Been thanked: 1332 times
Post by matthew1 »
Check fuel pressure (42 psi), airbox and filter, spark plugs and spark plug gap (.028 inch).
Also -> Amazon link
fredt2
Post by fredt2 »
Fuel pressure is nominal and pump seems to be working fine.
I think it could be the battery, these issues started just when the temp here went from 25°c to about 10°c in the morning(77°F to 50)
Voltmeter reads about 11,5v with the car off and lights on
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
I was thinking a vacuum leak, but when you mentioned the temperature being a factor, coolant temp sensor is what I'm leaning toward.
1999 V70 GLT
Has thanked: 1611 times
Been thanked: 4072 times
fredt2 wrote: 21 Apr 2023, 17:41 Fuel pressure is nominal and pump seems to be working fine.
That’s a dead battery!
fredt2
Post by fredt2 »
Well, thanks for the advice, i'll try to start the car with the temp unpplugged, see if It makes any difference, if not, then it's prob the battery.
Has thanked: 2209 times
Been thanked: 1852 times
As you mention, check the coolant temp sensor (ECT) by the thermostat. Also check it's connector by the power steering pump. Replacement we only recommend Volvo OE or Vernet ? (OE supplier) but that is not available in North America. The connector and the wiring there are known issues for corrosion. There are readings for testing the ECT on the website using resistance values and ambient temperature.
fredt2
Post by fredt2 »
Checked the thermostat, unpplugged it and the car ran the same way, so I doubt it's the problem. Also the connector seems fine, both ends are in good shape, sprayed some contact cleaner on it too.
That does not prove it is good. The ECU needs a signal to set parameters. You need to measure the resistance in the unit at ambient temperature (engine cold) to see if it is good. It is a pain to remove to check it over a range of temperatures as you need to remove it to do that.
When was the fuel filter last changed? Have you checked the fuel pressure as suggested?
Even though it is a non-turbo, you need to check all the vacuum lines are good.
When was the distributor cap last changed along with the rotor, plug leads and spark plugs? Have the plugs been gapped to 0.028"?
