850 remote lock/unlock doesn't work
Ernie9659
Year and Model: 1996 850 turbo
Post by Ernie9659 »
Replaced the remote's battery; no change.
Could it be a fuse or a relay?
Any DIY helpful hints?
TIA!!
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
Just checking... did the remote used to work on the car before the battery died? If so, then a new battery should restore function. If not, then you could try reprogramming the remote(s) to the car.
Has thanked: 2202 times
Been thanked: 1852 times
Try manually locking and unlocking the driver's door with the key and try again. Sometimes the remote locking system can get confused. Long shot but simple to try.
As suggested you can try reprogramming the key, but I would also re-check the new battery is good and the contacts are fitting correctly.
