P2 v70 Evap "J-Hose" Replacement Without Tears (mine is 2004 v70)
packetfire
Year and Model: 2010 v50 2.4i
Has thanked: 17 times
Been thanked: 30 times
Post by packetfire »
This all starts with a "major evap leak". There is a VIDA test that you can run in "vehicle communication", or you can just drive around for a few hundred miles and the test will run on its own, throw a code and light the friendly CEL.
First off, your VIN tells you which evap system you have - the P2 Volvo VIN 8th character. The "A" in my VIN tells me that I have a "type A" emissions system, and, on my car, the so-called "J Hose" is not at all "J" shaped. The dealer parts guy and I double checked, and he confirmed that yes, this was the only hose in the entire Evap canister area that had any significant sales in the region, so we knew it was the right one.
But it looked like a very shaky lower-case letter "n", not at all like a "J".
Second, forget what VIDA says about dropping down the exhaust system. Don't go there - your exhaust system, if it is like mine on my 2004 v70, is held together by firmly rusted-in-place components that will require a cutting torch to "drop down a few inches". Leave it be until if fails, and admit that the rusted flanges are better and more secure attachment methods than the bolts, which have rusted away and disappeared, leaving empty holes in the same flanges.
So, how to get at the J-hose? It is hiding with the evap canister atop the rear axle! But there is a way...
You need to get the car up on a lift. Maybe YOU can do this with the car up on ramps or jackstands, but I'd pay a guy to get the beast up in the air where we can work on it, as this took 3 guys under the car to do, but it was all over and done quickly. No more than 15 mins total after about 20 mins of listening to the mechanics moaning and groaning and pointing excitedly at rusty things, whining about having to likely replace everything in the exhaust system aft of the CAT if they tried to "drop it down".
DO THIS - You loosen the rear subframe mounting bolts, and LET IT DROP DOWN, rather than the exhaust. Two guys lean on pry bars to pull down the subframe, and one guy reaches in and does the surgery to R&R the stupid little skinny clamps and the hose. Pay attention to the clamps here, there is not a lot of room for a normal clamp, so you need to reuse the wire-type clamp, or use a similar wire-type clamp.
So, for some folding cash to the mechanics who provided the lift and assisted on the surgery, and $30 to the dealer for a hose, I no longer have an annoying CEL, and I can actually (gasp!) pass inspection.
The irony here is that if not for the built-in fancy test pump (rather than just the purge valve as the only moving part), the J-Hose would not exist as such, and would not vibrate so much and fail. Designing in the ability to test not only raised the cost, but also lowered the reliability. But HIDING the whole mess above the axle on the wagons was just plain mean.
Here's a photo of a P2 V70 rear subframe from eBay, as VIDA only shows one side of this beastie at a time in its diagrams
P2 V70 Rear Subframe
1982 240DL: Drove it 32 years and 1.5 million miles (sold, even still had mint leather!)
2001 v70 2.4T: The most expensive $1500 car I ever bought ("Volvo Turbo" - what an oxymoron!) (sold)
2004 v70: Far less fatally-flawed v70 - It served well (sold)
2010 v50: Smaller, slightly sportier wagon. Its got a spoiler, so I upgraded with sway bars!
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
You have a particularly rusted exhaust, I dropped mine several times last summer, 04 v70.
The rear most hanger rotted away but i made my own version and thats been good for 6 years now.
Its worth fixing as replacement exh aren't cheap.
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
I did that with the car's back sitting on 12" ramps, no need to pay anyone. You can drop the whole exhaust down quite a bit, the flex section allows that.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Over the years, I could not find out why this hose (not exposed to heat or the sun) cracks, a problem in P80 1994-1990 850, S70, V70...while other hoses in the engine compartment are OK.
Also an issue in P2 cars.
My theory is they use pure rubber hose not reinforced by fabric...
