96 850 Wagon - Replace Outer CV Boot Only
clarkr
Year and Model: 850 Turbo 1996
Been thanked: 5 times
Post by clarkr »
Hi,
I have a 96 Volvo 850 Turbo Wagon. The outer CV boots are bad/torn, inners are fine. No problem so far with CV clicking or needing replacement.
Is there a tutorial for just replacing the rubber boot without pulling the axles? Any help would be greatly appreciated.
Thanks in advance,
Clark
xanthefin
Year and Model: 1997 850
Has thanked: 106 times
Been thanked: 130 times
Post by xanthefin »
I think in edge terms what you saying where you don't still take it off from the car is use something what you can pull over axle after taking it off from the hub...
But if doesn't want to do even that then split cv boot which needs be glued in place is your option i am afraid.
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
Yea there are split boots that can be placed around the CV axles and glued together but they won't last as long. I've seen videos of people able to stretch a rubber boot over a funnel without having to remove the axle.
Has thanked: 2197 times
Been thanked: 1851 times
There is an actual tool for that!
https://www.dormanproducts.com/p-8162-614-035.aspx
Above is an example. Air powered. Not sure how it may affect the narrow end of the boot stretching it that much!
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
scot850 wrote: 01 May 2023, 23:09 There is an actual tool for that!
@Abscate -- I wish I bought a set of these =P
Has thanked: 1609 times
Been thanked: 4064 times
I think pulling the axle is the worst part, and I want it on the bench to clean and repack , anyway
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
clarkr wrote: 01 May 2023, 13:32 Hi,
Thanks in advance,
Clark
Disassembly of the stub axle from the half shaft takes brute force; the workbench or solid ground are your friends, along with a stout hammer.
Put a small catch pan under the transmission and pull the axle is my suggestion.
foggydogg
Post by foggydogg »
When you clean and repack these and look at the metal quality you will realise why you shouldn’t buy the crap from Stone Auto or OOO-URO-Rejects
