Hey All,
I have an 06 V70 that won't come out of park sometimes. It started acting up during the colder weather and I thought it may have been a possible sugary drink spill (no evidence but I haven't owned it since new), once the car warmed up it would come out of Park and work fine so I sprayed below the shifter with foaming glass cleaner.
All worked well until a couple of weeks ago but now it's worse, no amount of warming up helps, even if it's 70 degrees out. I can hit the brake pedal and feel a solenoid "clunk" in the shifter and see a black plastic piece underneath the shifter bezel move and return when hitting the brake pedal but it still won't release the shifter out of park.
In the colder weather I replaced the brake light switch with a new one but it didn't help.
Any ideas or suggestions would be greatly appreciated.
06 V70 won't come out of park Topic is solved
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
mine does the same at 20 below zero, I let it warm up,SVO LOU wrote: 02 May 2023, 20:03 Hey All,
I suspect the lockout solenoid at the shifter.
motormikeyman
- Year and Model: 2004 XC70 AWD
- Been thanked: 8 times
You will need to replace your shifter knob- very easy 5 minute job. Something breaks inside and it will not actuate the release rod to get it out of park. At least that's what it was in my case.
'94 940 wagon, 220K miles- sold to a guy who then drove it to Oklahoma
'99 XC70 AWD, 210K miles- trans went
'04 XC70 AWD, 196K miles- still going strong
'06 S40 sedan, 150K miles- went with the ex
SVO LOU
- Year and Model: 04 XC70, 06 V70
- Has thanked: 44 times
- Been thanked: 5 times
Appreciate the tips everyone.
When I was finally able to remove the key I took off the switch (the part on the left side of the lock cylinder) and used a wax-based bike chain lube to lubricate the interface between the two and opened the shutter of the lock cylinder and lubed that also. The cylinder then turned extremely smooth but the shifter would still hang up sometimes so it was actually two problems.
I then removed the shifter bezel and lubed around the left-side of the shifter (where you can see the white plastic piece moving when pressing on the brake).
So far, so good. Thanks all.
01, 02, 04 XC70, 06 V70
- 7802 Views
Last post by oragex
- 3052 Views
Last post by mouseskowitz
- 677 Views
Last post by billwann
- 14 Replies
- 2497 Views
- 2026 Views
Last post by joedrt77
