So I just got a good lead on a very low mileage B5234T engine and auto trans + all associated accessories out of a 94 850. Tried to do some quick searching. I know the B5234T is rated for less power than my B5234T3, but I believe the internals are identical. Are the heads identical? Is the only difference between the 2 ME4.4 vs 4.3 and a bigger turbo on the T3, plus maybe some emissions stuff? Basically, what changes a B5234T into B5234T3?
Will this be a direct swap into my 98 T5 (besides changing the flywheel for my M56) or will there be some things I have to do to convert the engine to ME4.4? Anything I should look out for before I fork over the cash?
Regardless, I'm assuming this will be a relatively simple swap without any big disadvantages vs sourcing a 98 B5234T3? Situations have changed and I really need to get my S70 back on the road ASAP.
B5234T vs B5234T3 swap
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
Knows enough to be dangerous
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
The longblocks should be the same, between 98 and 94. Both are 2.3T N motors.
Just bolt all of your 98 ancillary parts onto the 94 longblock and go.
- WhatAmIDoing
Did a lot of research last night. I think everything will be good to go. Just not sure if I will have to swap over the engine wiring harness to accommodate ME4.4?
- Chuck W
Leave all of the ancillary parts that are NOT engine/head from the '98.WhatAmIDoing wrote: 09 May 2023, 17:38 Did a lot of research last night. I think everything will be good to go. Just not sure if I will have to swap over the engine wiring harness to accommodate ME4.4?
Put everything, intake, exhaust. turbo, harness, etc from the 98 onto the 94 engine.
- 13 Replies
- 1224 Views
- 20 Replies
- 1573 Views
Last post by tersfilozof
- 700 Views
Last post by Chuck W
- 11834 Views
Last post by S23
- 3381 Views
Last post by Hoytster
