2006 xc70 replacing one tire?
- chris11211
- Year and Model: 2006 s60 2.5T
- Has thanked: 7 times
- Been thanked: 29 times
If it's AWD then you are stuck with buying 4 sets of tires every time regardless.
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
Alan -
They generally recommend against that, unless the replacement is the identical model and same tread depth.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
nah, that was only a problem on the earliest versions of awd.chris11211 wrote: 30 May 2023, 23:30 If it's AWD then you are stuck with buying 4 sets of tires every time regardless.
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
Many eBay sellers list tread depth, so you should be able to find the same model and same tread depth for replacement.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
goldxc70
- Year and Model: XC70 2004
- Has thanked: 27 times
- Been thanked: 3 times
Go to used tire place and look for identical model and wear tire as on other side. I've just had to do it and had a hard time finding one. Eventually I found a single tire with similar wear from same manufacturer, Michelin, but different model, Defender v Latitude.AlanS wrote: 30 May 2023, 22:15 One of my front tires has wear on the inner edge. I will get it aligned and evaluated. Is it ok to replace only one front tire? The other is in excellent condition.
If you don't have time to look around (I did), then just a pair as that's probably easier.
- 2065 Views
Last post by fontoledo
- 688 Views
Last post by ts888
- 1375 Views
Last post by erikv11
- 32 Replies
- 5089 Views
Last post by BlackBart
- 599 Views
Last post by treestone27
