2004 XC70 Low Coolant, Radiator Replaced
IlikemyXC70
Year and Model: 2004 XC70
Has thanked: 6 times
Post by IlikemyXC70 »
Hello. Last night I got a message saying to stop safely due to low coolant. When I checked under the hood, the coolant tank was low, but I also noticed the upper radiator hose was over pressurized. I opened the coolant tank (hot, just like you're not supposed to :)), there was a gurgling, and then the coolant returned, and the radiator hose went back to normal. It's only been a day, but it seems to be back to normal.
Any idea what could have happened?
I replaced the radiator about two weeks ago, and I had the thermostat replaced back in February. When researching the radiator repair, I read that there are no special procedures for refilling there coolant, and there is no need to "burp" the system. Maybe I read some bad information?
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
burp the system by squeezing the top hose, drive around the block and top the level up before it gets hot.
run the heat to make sure you're getting circulation.
At least get a torque android phone app so you can see what the actual coolant temp is.
I use this one, Its pretty slick for $10.
https://www.amazon.com/Generic-ViaBecs- ... 123&sr=8-3
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
Replace the expansion tank cap. FCP sells Gates 9445462, but I would go with genuine Volvo, as many of those aftermarket caps are known not to work.
If the new good cap will not help, you have a blown gasket or a crack in cylinder.
IlikemyXC70
vtl wrote: 09 Jun 2023, 07:48 If the new good cap will not help, you have a blown gasket or a crack in cylinder.
I sure hope it's not that :0 But, I think it was just an air bubble in the system. I didn't flush the cooling system after installing the radiator. Whenever I do cooling system work, I'll get the low coolant warning after driving a bit, so I stop to top it up. Thinking back, I believe there was a pocket of air trapped in the upper radiator hose, and, against recommendations, I think opening the recovery tank hot allowed the air bubble, which had risen to the physically highest point in the cooling system, to escape.
Regardless of what it was, or still is, we're driving fine. Might even get a carwash today before it rains lol
jonesg
Post by jonesg »
IlikemyXC70 wrote: 11 Jun 2023, 08:17
There a quick test for head gasket failure, with the engine stone cold in the morning, open the coolant cap, if its under pressure.... you have a problem. Further testing can quickly confirm.
I used a bottle of water, some clear hose and a spare coolant cap, drill a hole, insert tube through coolant cap and run the engine, if air (gas) bubbles increase and decrease with rpm the system is breached, probably gasket.
IlikemyXC70
Update: I checked the recovery tank for pressure, cold, yesterday morning, and there was some, but not as much coolant returned to the tank this time. I checked again this morning, cold, and no pressure at all. :)
I'm currently thinking I did not purge all the air from the cooling system after replacing the radiator, and I think that is what was causing my problems.
I have a new recovery tank cap on the way along with an oil change kit. The cap is about $7 from FCP, so I'll replace it just in case.
