Hi All,
I want to install a performance fuel pump and manual fuel pressure regulator, any suggestions on a good brand for the pump? I've already bought the regulator from Snow.
Thanks,
Performance Fuel Pump
gizmaster_1
- Year and Model: 850 Turbo 1995
- Has thanked: 5 times
- Been thanked: 3 times
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Robert put a DeatschWerks DW200 in his R that runs a tune, takes a bit of fiddling to get it to fit in the plastic housing.
gizmaster_1
Thanks foggydog, I will look into it Doesnputting in a performance pump mean more power? Or do you need a tune to get more pressure/performance out of it?
- misha
- Has thanked: 155 times
- Been thanked: 432 times
It needs a tune.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- foggydogg
A fuel pump with higher volume potential provides enough fuel for bigger injectors and the other things that go into making more power. It's more of a concern for folks who regularly thrash their cars, but the presumption is that high-performance pumps are a built a bit sturdier. Keep in mind the stock OEM pumps last pretty well, too.gizmaster_1 wrote: 13 Jun 2023, 09:20 Thanks foggydog, I will look into it Doesnputting in a performance pump mean more power? Or do you need a tune to get more pressure/performance out of it?
- 42 Replies
- 12067 Views
Last post by Maestrours
- 5074 Views
Last post by wizechatmgr
- 16152 Views
Last post by Richard99
- 2491 Views
Last post by matthew1
- 24 Replies
- 12274 Views
