The dealer was less than helpful suggesting I bring it in so they can charge me 8+ hours to "drop the tank"
04 XC70 Engine Cuts out at Speed
jeb8020
- Year and Model: 2004 XC70
- Has thanked: 2 times
Hey all. Looking for some insight. I had my fuel pump replaced a year ago and since then my otherwise trusty XC70 will cut out at highway speeds with the fuel tank always at 1/4-1/2 full. Once I pull over it primes and starts up just fine.
I had thought the siphon was dangling loose or the fuel gauge was misaligned but neither seems to be the issue. Does the wiring on the level in the attached photo look appropriate? It doesn't match what I'm seeing in videos whatsoever. Any other help much appreciated!
- Has thanked: 987 times
- Been thanked: 1076 times
This sounds to me like a fuel pump or fuel filter problem. Both should be evident with low fuel pressure at highway speeds. Try to add a fuel pressure gauge from the bleed valve at the end of the fuel header on top of the engine. Run the gauge line and gauge to be visible while driving. Then hit the road.
- Has thanked: 1611 times
- Been thanked: 4072 times
They may have kinked the crossover pipe that feeds the two saddle tanks. It’s a common error.
Yeah, hose kink possible. Likely to give problem at high flow and low tank level.
- 923 Views
Last post by oragex
- 1025 Views
Last post by jonesg
- 1093 Views
Last post by Redbox
- 1505 Views
Last post by cbburtraw
- 1056 Views
Last post by philthevolvo
