Could there be something wrong with the computer? 1998 v70
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Post by MrAl »
Hello there,
I checked another person's car today for OBD2 codes and i was quite astonished that the reader read the codes in less than 10 seconds. I thought i was going to have to wait to see the results, but when i looked down i could not believe it read the entire information already.
This leads me to believe there is and always has been something wrong with the computer in my 1998 v70. It has always taken about a minute and a half to read the codes in that car, whether there are trouble codes or no trouble codes.
Any idea why it takes so long for this car, and it is like this for your Volvos too?
Thanks for any info about this i am trying to get to the bottom of what this car is doing and why it is doing it.
Has thanked: 2200 times
Been thanked: 1852 times
What year was your friends car, and was it a Volvo?
V50M66
Year and Model: 1998 V70 AWD
Has thanked: 26 times
Been thanked: 94 times
Post by V50M66 »
What tool are you using to read your ‘98? My ‘98 takes about 5 mins to read every system with the 850 OBDII app and a cheapo Bluetooth reader
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
1999 Saab 9-3 - daily
2004 XC70 - former workhorse, parted
2005 V50 T5 M66 FWD - former garage queen, sold
2002 S40 1.9T - former daily, rear ended
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
On my 1997 855, using an old Actron handheld OBD2 reader I bought used on eBay a long time ago, it takes about 2 minutes to read codes.
MrAl
Post by MrAl »
scot850 wrote: 19 Jun 2023, 13:03 What year was your friends car, and was it a Volvo?
Hi Neil,
That car was 1998 Buick.
My reader is Actron CP9575 about $100 USD new.
MrAl
Post by MrAl »
V50M66 wrote: 19 Jun 2023, 13:55 What tool are you using to read your ‘98? My ‘98 takes about 5 mins to read every system with the 850 OBDII app and a cheapo Bluetooth reader
Hi,
Using Actron CP9575 about $100 USD new.
MrAl
Post by MrAl »
jreed wrote: 19 Jun 2023, 16:10 On my 1997 855, using an old Actron handheld OBD2 reader I bought used on eBay a long time ago, it takes about 2 minutes to read codes.
Hi,
Mine is also Actron, model CP9575 about $100 USD new.
Think that makes the difference?
xanthefin
Year and Model: 1997 850
Has thanked: 106 times
Been thanked: 130 times
Post by xanthefin »
Buick uses VPW J1850 and Volvos are mostly Slow init (30 sec per module init roughly max and min 2 seconds) ISO 9141-2 and that other one "McMess" which could be faster but ex. ELM327 cannot do it really and i havent met any other than VST using it.
Actron seems use Standard OBDII so you need on ELM327 if you just want replicate it something couple commands like 0100, 03 and 07 to receive Pxxx codes from one single unit which ever supports standard OBDII. Volvos its either ECM or TCM and rest units wont support Standard OBDII even that. Then you can add more commands get more data out of it if you want.
Each command takes 100ms have received message but varies per protocol and message length.
Now if want compare ex. 850 App uses when connecting directly each individual units and their own fault codes and other info it totals like hundred messages when doing multi unit Scan (363 commands as example in one log) and gives wait time on some messages to attempt to have successful init on some units which otherwise just would fail. Single unit Scan its way less commands and time but still. Plus need first setup ELM327 in correct settings make it all possible.
Summarum your V70 is fine.
MrAl
Post by MrAl »
xanthefin wrote: 19 Jun 2023, 21:30 Buick uses VPW J1850 and Volvos are mostly Slow init (30 sec per module init roughly max and min 2 seconds) ISO 9141-2 and that other one "McMess" which could be faster but ex. ELM327 cannot do it really and i havent met any other than VST using it.
Hi,
Oh that's interesting, thanks for the info.
What do you think makes this car take so long to get the monitors ready then?
That's another big problem. The monitors take so long to go ready, and even after driving another 100 miles they still are not ready.
I had this problem some months ago too.
Thanks.
Abscate and others have posted the drive cycle the cars need to on to get the monitors to set. If he sees this or PM him and see if he knows where the link is.
