2004 V70R - Can only shift from Park to Reverse Topic is solved
hharrell4th
- Year and Model: 2004 V70R
- Has thanked: 1 time
My 04 VR shut down a couple of weeks ago and it had to be towed home. The fix was to replace the PEM but once I got every running, I'm unable to get past reverse. I hear the shifter repair fixes similar problems but I've searched and can't find anyone who was just stuck in Park and Reverse. Any ideas?
hharrell4th
Part ordered...wish me luck!
hharrell4th
Solenoid and shifter claw kit replaced but still not able to shift past reverse. Any other ideas before I give up?
- jonesg
- Has thanked: 73 times
- Been thanked: 532 times
can you hear the interlock click when pressing the brake pedal.hharrell4th wrote: 05 Aug 2023, 14:20 Solenoid and shifter claw kit replaced but still not able to shift past reverse. Any other ideas before I give up?
installing a solenoid doesn't mean it moves.
hharrell4th
Yeah, I've tried that and it seems to be an issue with the shift cable binding, not the actual gear selector.
- Been thanked: 504 times
I have been here a long time and have never seen a seized cable.
I guess you can replace the cable and see what happens.
PS: Have you checked inside the engine compartment to see if the cable moves freely?
hharrell4th
I confirmed the cable is fine. I got a suggestion to take out the shifter assembly and thoroughly clean all the goop out.
- Has thanked: 311 times
- Been thanked: 817 times
And that fixed it?
